Changing Battery
General discussion area for the L32-chassis Altima
scttybb
How do you reset the warning codes when you replace the battery?
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
Just leave the battery unconnected for a few mins and that will clear the codes. You shouldn't be getting any codes just from replacing your battery. If you are, then you need to get the codes read and find out what's causing them.
Return to “4th Generation Altima Sedan (2007-2012)”
