Changing AT Fluid
hwayne1
I need some input. I have a 2005 G35 with 37K miles. I'm kicking around the idea of changing my transmission fluid. I'm 54 and am fairly competent on my tools.Is this something I could do myself without getting my stress level up or spilling much blood? Have any of you done it yourself? What is the downside?
-Wayne
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
I would take it to the dealer and have them flush the trans. Changing the fluid will only get about 1/3 of the old fluid out. A flush will get about 98% of the old fluid out.
Plus it will save the stress level and blood loss.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
Doing it yourself you may be able to get 4 qts at most out of the pan. There is a defined procedure in the book which involves filling it while draining is through the lines into the radiator. Personally I have never tried that, we use a diaphram style fluid transfer device that cycles out the original 12 qts of Matic J and directly replaced it with virgin fluid without coming into contact and without making a mess.
Dropping the pan and replacing the filter is not really done on this car. There is really no filter median that requires replacement, there is a metal screen that (if maintained correctly) should never need to be cleaned. Plus under normal operation and even pretty vigorous driving is still designed to last ~60k or ~5 years. That is just a rough estimate and early maintenance are always great.
May be one of those things to take in, if something goes wrong you may be up a creek and out a transmission.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
When I drain my transmission I get 5-6 quarts out. If its not your daily driver and you can let it drain for longer than the 30 min that I did you will get more out.
Otherwise, I would drain and fill. Drive around for a couple days and do the same thing again.
Its not too much different from changing your own oil if you do it this way...just more expensive fluid.
