changing an alternator
Rager
Car: 1992 Nissan 300ZX 2+2
1999 Nissan Sentra
2004 Chevy Silverado
Im looking for a write up to change an alternator in my 99 nissan sentra. Any one have a write up or any info. Ive changed alternators before but not in this car. Im assuming its pretty much the same , im just looking to see if anyone has any other usefull info.
Thanks
300ZXttZMAN
PapaSmurf2k3
Site Admin
You could also check out the factory service manual. There's a link to all of them in my signature :)
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
i don't remember if i had to do one on my old b14, but everything about that car was fairly straight forward. i imagine the biggest hurtles will be accessing mounting bolts and maneuvering the old alternator out and the new one in.
Dattebayo
The most important thing to know is what engine you have.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
FWD alternators are always a bit of a PITA, since they tend to be crammed against the inner fender. But they're not terrible. Really, the toughest part tends to be releasing the tensioner pulley so you can get the belt off--the pulley is ALSO crammed in between the block and fender and there's not always a lot of room for moving a wrench of man-sized arm.
Remember to disconnect the battery or you'll probably get a fun surprise while trying to unscrew the thing.
Dattebayo
Sentras are usually good for having a removable panel in the wheel well for that kind of stuff also... remove the passenger wheel and see if you have one.
