Hi, I'm at the stage of assempling everything back together on my SR swap. As recommended by a lot of members, now is a good time to change out all the rubber hoses. However, I'm not too sure about what rubber hoses/vacuum lines to use and where to buy them.
I've heard the best way is to take the old hoses to Kragen/Autozone, then cut it to my desired length. Are these hoses in local store having the same quality as the factory Nissan ones?
There are basically three jobs for the hoses: delivering air, oil and water. Are the hoses for each of the jobs using different material or it is the same rubber hose/vacuum line that does all the job?
Lastly, there are hoses like the heater hoses that has a "S" shape, do I have to get factory "S" hoses for it or I can just bent a universal hose?
Thanks!
