I'm on the same page with the heat exchanger routing. I do have one of the "standard club issue" Hayden/B & M external coolers that I planned to mount between the radiator and the A/C condenser coils for running fluid through it after leaving the radiator heat exchanger.elwesso wrote:The difference between the 90-93 and 94-96 on the fan is the 90-93 has a less wide, but larger OD fan, where the 94 has a smaller OD but wider blade fan.. Other than the trans cooler, i don't think much is different on the physical side of the radiator. In other words, I wouldn't worry about switching to the newer style fan and shroud.. Its possible also that the 94 fan pulls less air than the 90-93 since the early ones were sans grille, but who knows?
I am not 100% certain how the ATF circuit works on the 94's, never really cared to investigate it much. However the way I would do it on your setup is have a cross-over from one side to the other on the radiator, so basically its getting a "dual pass".. So have the fluid go in the bottom on one side, out the top, in the top, then back out the bottom, through the filter, and back to the transmission.. Thats how I would set it up.
Better yet, just ditch the radiator heat exchanger for a proper external cooler..
That's what I did, and I have had the same transmission fluid in for nearly 10K and it is still bright red and smells new. This is after multiple trips to eastern WA last summer driving up the pass in 100+ degree heat. I'm due for a fluid change, but definitely believe the way to go is delete the factory cooler and go with the B&M unit only.elwesso wrote:Honestly I think thats making things more complicated than it needs to be. Just skip the radiator heat exchangers and go right into the external cooler.
qship96 wrote:I will throw in my 2 cents worth of information ........the proper routing for the use of the dual coolers is as follows.
single line delivering atf from transmission goes into the oem atf filter cartridge by battery- it exits the filter via 2 separate ports on the bottom of filter with 1 hose going to each in-radiator heat exchanger......the output line from each exchanger{1 hose each} then gets connected to a Y pipe adaptor where it connects to a single line back to the transmission.
If you decide not to use the in radiator coolers for the atf {using an external cooler instead}, then you might want to use a single, or both in radiator coolers for cooling the power steering fluid by rerouting the PS return line through them
*********************** IN MY EXPERIENCE, using the dual in-radiator coolers as designed {for the 94-96 models} {to cool the ATF} is sufficient to optimize the life of the transmission, and the power steering does not need any additional cooling modifications......282,000 miles on original transmission and PS pump and rack lead me to that conclusion. If you track the car, or drive it like a teenage boy who just got his license......your results may differ,as the saying goes.
Nothing gets by you, Paul!Infinitiguy19 wrote:Using the OEM transmission cooler on the radiator as a power steering cooler would increase the capacity of the power steering system.
Here's how it turned out..qship96 wrote:I will throw in my 2 cents worth of information ........the proper routing for the use of the dual coolers is as follows.
Good points. I'm going to the the L10 transmission from Wes then send it to L10 for a torque converter and freshening up.qship96 wrote:Are you rebuilding your current transmission? I would use the cheapest genuine dexron ATF you can find to refill the transmission after initial rebuild/install......because I would run the rebuilt transmission for about 5000 miles, then replace all the ATF again as studies show the majority of wear particles in ATF occur during the breakin of new parts in any auto transmission.I would use a high quality Real, true 100% synthetic atf for this second fill- then simple 4 quart drain/fill every 15,000 miles for as long as you own the car using the same synthetic atf. Magnefine and aftermarket cooler is fine if carefully installed and plumbed.
