Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Tue Oct 12, 2004 4:50 pm
use a 12 point 17mm socket for the fill plug. it's not an exact fit do to the squareness of the plug, but it's close.
i don't recommend just filling 2.5L into the trans. It's best to fill till it dribbles out the fill hole. a lot of times, extra fluid is trapped in the trans, so when you add 2.5L into it, you may have an extra .5-.75L of fluid still in it making you have over 3.0L
