Changin cv axles.
tps2000
Car: 2000 Maxima gle
I have a 2000 maxima and my axles need replacin. How hard is this process? Ihave been scared by a few mechanics who say it is very hard and in my Chilton book it dosent look that difficult. I am pretty good with tools and werkin on stuff. Tanx.
lightsout
Car: 00 Nismo Maxima SE
i just did both of mine last week!!
the driver side is eeeeeezzzzz!!!
the passenger side it s little bit harder b/c there are three little bolts you've got to remove before poping it out of the transmission. just use your 3/8" drive socket wrench, 3/8" elbow, with the 12mm socket, one 6" and one 8" extensions, and snake it through from the left side of the crossmember. you will also need a 1.25" impact drive socket and a breaker bar with a metal pipe extension to remove the axle nut on the outside of the hub.
pix
my passenger side pix:
my driver side pix:
make sure you get the driver side snap ring to sit all the way in so your dust shield is flush with the axle seal. to remove the driver side use a GIANT flathead screwdriver or a short pry bar and some muscle(not too much, work it slow)
Modified by lightsout at 12:10 PM 2/19/2009
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Awesome post!
jmanders
Car: 97 Maxima Gold Edition
Yea thay are actually really easy to replace, it is good to have a rubber mallot to hit the new ones in. It is also good to get an alignment after you change them.
lightsout
ah, the rubber mallet good reminder jmanders!
i only used the mallet on the driver side b/c of the snap ring. the passenger side doesn't have a snap ring, it has the mounting bracket
CHORAY911
Car: 96 MAXIMA, W/VQ30DEK &TO4E Turbo, 13" 300ZX Brakes, 10" TV in the dash
It takes more time to find the right tools, and get the right socket to take off the hub nut, than it does to change the axles. If you have the right tools, maybe an hours worth of work. The mechanics were trying to scare you cuz they wanted your money. Two bits of advice; keep a 3# sledge to hammer the axle out of the hub, and make sure you have fluid to refill the transmission, cuz it will leak out.
jmanders
The transmission fluid did not leak out when I changed my axles.
CHORAY911
jmanders wrote:The transmission fluid did not leak out when I changed my axles.
In that case you didn't have enough dope in the transmission.
lightsout
mine leaked out b/c i left it sitting without the axle in it for a few days...crap came up and drivewire.com sent me a CORE from another company instead of a new axle.
don't ever purchase from drivewire.com.....NEVER EVER
horrible customer service, and very unprofessional with a major lack in customer service ethics.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
It might cost an extra 10$ but I would change out that trannyseal where the CV axle goes in. I took my car in once and theyput in a new CV axle but they made the transmission leak by roughingup that seal putting the axle in. they charged me $ to fix theseal then
