Qxxx4 wrote:Ch3(+) <--> + Sub1 - <--> (-)Ch4
this should give you 700W @ 4ohms if bridging CH3 and 4 this way doubles channel power
Qxxx4 wrote:I then connected sub2 in series with sub 1
So it would look like this Ch3(+) <--> (+)Sub1(-) <--> (+)Sub2(-) <--> (-)Ch4. This will give you 8ohms. You are now getting 350W@8ohms into your two subs, where in the above case, you were getting 700W@4ohms into one sub.
Qxxx4 wrote:So, from my understanding I have 8ohms of resistance, and approx 700W feeding the subs right?
Wrong. See above comment.
Qxxx4 wrote:do you guys think my subs can handle this? their SVC with 300W RMS and 600W peak...i dont care about the amp but i love these subs.
I think your subs should be fine. Yes, they are rated to handle 300W rms, but 175W while in series isn't anything to sneeze at.
Also, when "tuning your gain", its best to use as little gain as possible. Find the spot where it sounds the best. Make sure your radio is set at "0" Bass when doing this. The idea is not to go above "70%" gain. In fact, no higher than "50%" gain is better, but each amp and car is different.
Once your gain is set, now use the radio EQ to fine tune the sound to your liking. Going back and tweaking the gain might be necessary, but only a small tweak should be all it takes.
Example wiring article --> Series vs Parallel
Modified by K03sport at 9:18 PM 5/26/2009
