Metal Militiahttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Changed Water/Oil Pump & Timing Belt Now Wont CrankTue Sep 15, 2009 5:26 pm
Postby
Metal Militia »
https://forums.nicoclub.com/metal-militia-u17128.htmlTue Sep 15, 2009 5:26 pm
Just changed the oil and water pump and timing belt, now when I go to crank the motor by hand it wont budge. I did leave the oil pan off for about a day and a half could this have caused the motor to sieze? or did i install the oil pump wrong? Thats the only things i can think of to why i cant turn the motor by hand. The motor is out of the car if that matters.
Modified by Metal Militia at 6:44 AM 9/16/2009
Postby
Darius »
https://forums.nicoclub.com/darius-u5470.htmlWed Sep 16, 2009 3:38 am
Dumb question but is the transmission in neutral??
And do not push it if it won't go. The valves are very prone to breaking when they're sticking out and making contact with the piston if that is the case.
Postby
Carl H »
https://forums.nicoclub.com/carl-h-u9196.htmlWed Sep 16, 2009 5:57 am
sure you have everything set properly...there is a right and a wrong way to line up the cams...easy to do if you're not paying attention.cam lobes must face OUT.
