changed turbo now problems
cobhc
so i just installed a 2871 now i got white-ish smoke but smells like burnt oil. any ideas? i had a s15 turbo previouslyand i used the old lines too. thx
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
What's the rest of your setup?
cobhc
stock bottom,cometic hg, 525cc top feeds, 264 cams, cams adv. 2.5 deg.
PyR0NiAk
cobhc wrote:stock bottom,cometic hg, 525cc top feeds, 264 cams, cams adv. 2.5 deg.
What are you using for tuning?
cobhc
neo
PyR0NiAk
2871 new or used?
(Sorry for all the questions instead of a quick answer. Just trying to narrow down possible reasons.)
cobhc
new. i checked for kinks in the lines too. im thinking its a freak accident
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
What kind of ECU are you using?
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
He said neo, so I'm assuming he's using a SAFC. OP get rid of the SAFC and get a real tune (ROM, NIStune, Standalone, etc.) Since you had the S15 turbo previously, I'm also assuming that you use an oil restrictor for the turbo?
cobhc
im gonna take it all apart and post pics of what i find
