evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sat Nov 03, 2007 8:02 pm
this is the problem with the crappy bosch L jetronic fuel injection system on the 280zxt, that little falpper thing is the mas aor flow meter (MAF) and yes you have to have it so long as you run the stock engine management, the air being sucked through it moves taht vane which is hooked to a sort of potentiometer which along with rpm and temp allows the ecu to decide how much fuel to let in, the problem with juet replacing that rubber pipe between the maf and the turbo inlet is that the your cold start depends on the metered air not used for idle to be placed back into the intake path with other metered air, so you're best bet is to cut it back or otherwise adapt the stock pipe to fit the turbo or use hard pipe with an extra nipple on the side for the idel air return circuit, or you can remove all the stock injection harness and run a stand alone like megasquirt which allows you to run a MAP sensor instead (this is what I did)
now the other problem you have is that the larger turbo flows more air then stock so you will now be lean, you need to flow extra fuel, with a stand alone you can program it to deliver more fuel or the easy fix is to use an adjustable fuel pressure regulator and up the fuel a couple lbs, you'll be rich at the bottome but at least you won't blow anything up from being lean up top
as for intercooler, there is a hks or greddy kti one available for the s130 chassis, the problem is it costs as much as the car, treadstone makes a good vertical flow intercooler which lends itself th the engine layout, and plan on dropping two or three hundred bucks on pipes , silicone hoses and clamps
back to the inlet piping, you can get piping and silicoln in the 3" that you need but remember to add a fitting for the idle air circuit if you plan to stick to stock injectioon, and the stock fuel pump and injectors will max out at about 250 whp
also what turbo did you use? there are lots of possible t3 t4 combo's and I don't trust offbrand turbo's
