Changed TPS Sensor Now A/T Light Blinks on start up
natec76
Car: Infiniti J30
I changed my TPS Sensor and now the A/T light blinks on startup. I disconnected battery to do install can anyone help?
infinitidreams20
Car: 1994 infiniti J30T
it could be unrelated just weird timing the blinking is a "warning" so to say if you read the book it says to get it looked at if it stays on some is bad i only say this because i dont see how just changing a sensor would set off some thing else.
94J30
Car: 94 J30
natec76 wrote:I changed my TPS Sensor and now the A/T light blinks on startup. I disconnected battery to do install can anyone help?
Good bet its the Vehicle speed sensor. Intermittant failure, Flashes at startup half dozen times or so, and then goes off. Mine did the same thing.
