changed to q45 brakes on S14 and now thumping on left turn
fluidmotion
Car: 1991 300zx TT, 1999 Miata, 1998 Audi A4, 2000 R1, 1996 FZR 600R
So, I got all new q45 rotors and used calipers with new metal matrix brake pads for the front brakes.
I got everything installed and bled the front brakes. So I took the car for a test run, slowly at first to make sure they worked. And they worked fine. There was some rubbing that you could hear, but I think that is because of the new brake pads and new rotors, if I could confirm this that would be great.
I heard that you need to do some hard braking to break in the rotors, so I started braking fairly hard. After some time, there was less rubbing on the pads, but then I could feel and hear a constant thumping under the clutch area. The wheel didn't shake, so it couldn't be anything related to alignment. The thumping would also increase the faster I drove.
I then noticed that the thumping would increase in strength when taking a left turn and decrease in strength when taking a right turn. I'm not sure what this could be, so if anyone has any ideas.
I did read on a different post that it could be the wheel weights? ....
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
Haha the only time my car thumped when I turned, and it was harder when I turned more was the night I nailed a curb. $1500 worth of suspension work later.. Lookin' good as new.. (stock) Did you make sure your pads settled in ok? Need to take it easy for a good 1000 miles for the pads. Make sure they're put in properly.
