putang29 »
https://forums.nicoclub.com/putang29-u150951.html
Thu Sep 30, 2010 6:04 pm
So i finished changing my timing belt today (refer to z32 general topic timing belt change gone wrong). Ill try to explain in as much depth as I can from timing adjustments to the not starting deal.
Timing belt: timing belt back plate marks aligned with timing belt lines and sprocket marks. I applied the autotensioner and rotated it by hand to hear for any metal on metal madness. When rotated, the belt lines moved but the sprockets and back plate marks maintained alignment. I also used a skinny screwdriver on the #1 piston to observe the piston at TDC when marks lined up.
I then torqued all bolts removed to spec, added drive belts, installed fan, then radiator. I did not put the timing belt covers back on. I placed the PTU in a new location using the bottom screw of the fuse box and bolted it there. I reinstalled spark plugs, coil packs, and balance tube. I made sure that all connections were made. CAS, PTU, and coil pack connectors, IACV and other small one next to it. I had the battery charged because it drains out randomly (im still looking for the cause) and attempted to start the vehicle.
The first time I tried to start the car, the starter was insanely strong due to the battery being on charge, yet it did not start. I tried again with no luck. I am now stuck with no car and no clue as to why it wont start.
