Thanks for all the info. The car has 102k and the front rubber hose that came out of the front of the thermostat wasn't cracked or brittle but the cover that the hose attached to was corroded so I scraped and cleaned it up (I presume that all hose connections will be like this). I Ohm'd the injectors and have to replace the #1. I have dealer documentation when the previous owner (at 97K) had the MAF, spark plugs, #3 injector, and O-rings/Collars/Gaskets replaced on the intake along with cleaning. I'm gonna do the chain guides at the same time so it'll be a whole weekend of wrenching.Q451990 wrote:Your profile doesn't show the mileage - but on a 14year old Q I would replace ALL of the hoses under there. They're going to be brittle. The leak could very likely be the hoses that go between the left and right banks. I would inspect the knock sensors for cracking under magnification, and strongly consider replacing them and their harness if you're anywhere near 100K. Ohm your injectors while they're easy to get to, and check the harness and connectors for any corrosion. I would unplug everything electrical and put di-electric grease in there. Be sure to buy a case or two of brake parts cleaner (or BG throttle body cleaner) for the plenum, throttle body, rocker covers if you reseal them, EGR Valve, BPT Valve, and port. Buy some new rubber o-rings for the plenum to runner junctions - and a foot or two of fuel hose. Might as well replace the PCV valve while you're under there too.
Rocker covers have some overlap with plenum removal, but not a lot. If you decide to reseal them allow for an extra day to scrape and seal them. An angle griner with a "scrubby pad" attachment makes it a lot easier. I also like to let the RTV set up for 12-15 hours before running the engine too. I prefer the Permatex Grey over the Nissan orangy/red stuff. T3 uses BG Black, but I don't know if it's readily available.
Good luck!
Heath
