Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jun 06, 2008 9:01 am
Swapped motor or came from Japan land with an SR?
You need to start doing the usual checks for a non-start:Do you have spark?Do you have fuel?Do you have compression? We'll assume you have this one since the car was running, and a dead battery caused your problems.
The easiest way to check for spark is to pull the #1 coil pack, and put a long screw driver into it. Then set the screw driver down on something metal and have someone crank the car. Make sure you're not holding the screwdriver, or you'll get a nice surprise.
To check for fuel, pull a spark plug and do the sniff test on it. Most times on a non-start issue that is getting fuel, the plug should be wet with gas.
Knowing if your car is a swapped car or if it's a real 180SX helps a ton as most people here have 240s with swapped SRs.
