Changed Starter and Need Help Identifying Extra Plug w/Pics
Downs2001
So about two years ago my starter went out on my 97 SE 4x4. I really never used the truck except for weekend errands and what not so I wasn't in a big hurry to fix it. I finally got around to replacing the starter but am now left with an extra plug that I apparently unplugged when I pulled the starter out.
The plug comes off of the same harness as the starter plugs and the the harness continues down to the transmission. It sits just a few inches further down than the starter wires and is about 10" long. It appears like its wrapped in heat shielding and also has orange wrap on it.
The problem is that the harness is loose and the plug looks like it could either go somewhere down by the transmission or up in the engine bay somewhere. I have looked for hours but can't find where it goes, any help would be appreciated.
whomadewho
Car: 1997 Nissan pickup
I have a 1997 Nissan SE 2.4 with a 5 speed. I changed the clutch and have the same issue. Check and see if the indicator light for 4 wheel drive works.Check and see if you have back up lights. There is also a plug on top of the bellhousing. My thoughts - One size fits all,the harness was used with auto and standard,the plug MAY have something to do with that. Let me know if you find a spot,mine is still hanging with a wire tie
Downs2001
I can't get it to start and wasn't sure if this had anything to do with it or if it had just been sitting too long. I will check those things. Thanks
Downs2001
It was the plug on top of the bellhousing, but I can't get it to start still.
whomadewho
Does the engine turn over??? If the engine turns over - check for spark - pull the distributor cap and check for moisture - you can remove the air cleaner cover and spray a small amount of carb. Cleaner, replace the cover,turn it over and see if the engine fires. When was the last time the fuel filter was changed. The diameter of the filter is quite large,it's possible the filter is clogged from old gasoline. Make sure all the wires going to the starter are hooked up. -Good luck
