daveh93s13 »
https://forums.nicoclub.com/daveh93s13-u90025.html
Wed Mar 26, 2008 2:51 pm
im glad im not alone with this problem. however i think mine is more serious than your describing. im getting a rough idle, that has that thudding noise, its not a clean smooth idle like a inline 6 should have. it stays this way all through its rev range, when building boost it has a jerky hiccup that dosn't pull hard like it did. the car started to act this way only at full boost. it started two days ago. then today i pulled the plugs, i found out the bcpr5eix-11 iridium ngk plugs were in decent shape, but the connector for #6 cyl coilpack was broken, i super glued the connector untill i get to the dealer to get a new z32 pack. as far as the plugs, i searched and found that the plugs should have 1.1 gap, they were at 1.0. so i set them to the 1.1 and cleaned them. when i reinstalled the plugs and repaired the connector to the coilpack, i started it and now its worse than it was before i started. its got the rough thudding idle and it is falling on its face throughout the rev range. rb20det in s14 with FMIC, 3" exh, test pipe, walbro 255lph.
