Cpt_Impossible »
https://forums.nicoclub.com/cpt-impossible-u43114.html
Mon Mar 31, 2008 5:25 pm
I am copying my post from SAU since no one seems to be giving me any feedback there
S13 240sxRB20detStock TurboStock Injectors3" Downpipe back, no cat255 pumpNismo AFPRStock intake pipeM's K&N FilterFMICStock BOV (plumbed) and HKS Super Sound (open vent)MBC
I had my car dynod, made 170rwhp on 12psi and 191 on 15psi (accidentally went too high on MBC). Around 6,200 the power would drop and the AFR would drop into 10:1. There was some concern as to the dyno calibrations but I figured new plugs wouldn't hurt. Switched the plugs from NGK 5's gapped at 1.1 (tips looked OK) to NGK bcpr6es-11 which I gapped down to 0.86mm. While I was doing this, I swapped out the engine covers for some painted and modified ones I had and remembered that long ago, I had removed the Crank Angle Sensor without realizing the implications and I had no idea what timing was set to. So I got the plugs, in, swapped engine covers, and set timing to 15 degrees btdc using the black loop. Had to turn the CAS almost all the way to achieve 15 though, if it was in the middle, it was around 25. I have heard that 15 should be right about the middle of its range of motion so I thought that this was odd, but timing belt shouldn't have skipped or anything, It is a Greddy super strong put in only like 5 thousand miles ago (assuming the tuner installed it correctly). All of the coil packs looked great, didn't notice any cracks after inspecting each.
So I get all of this done and notice that the car has a slight miss occasionally at idle (a lot better when timing was set to 15). And after driving it today it seemed slow. It revs fine at a stop and can hold any rev fine without missing, but when in motion, it seems to take longer for the tach to climb than previously. Inspected for any vac leaks and couldn't find any, even sprayed vac connections with carb cleaner, and idle didn't change at all. Inspected the open vent BOV by putting my hand in front of it while I rev and it doesn't seem to push any air until it gets vac signal to release.
Maybe because timing was set so advanced before, so before it would climb rapidly and then have knock issues up top and go into R&R? Car runs great, but just seems to lack the power it had before I did the plugs and set timing. I would think if all it was screwing me up on the dyno was plugs and timing that I should see 40whp or around that in gains from correcting it, but the car seems slower still.
Any suggestions?
_____________________
A friend suggested that instead of using the black loop by the igniter to set timing, I use the lead to coil pack #1. Is that correct? Maybe I am getting the wrong signal and set timing too far back, that would explain why the car is sluggish and the CAS is almost all the way turned down.
So I changed out the spark plugs for the V power ones in a 6 heat range pregapped and double checked to be at 0.8mm. Didn't change idle at all, still seems to have slight misses. The NGK BCPR6ES plugs that I pulled which were only 3 days old were flat white on the grounding arm though. Not sure if I was actually running super lean or if it was just because most of the time the car was running during those 3 days was at idle and adjusting timing where the engine runs leaner rather than driving it.
I read on NICO club (US forum) that timing using the black loop for timing would read higher than it actually was and that using the black loop, you wanted 25 btdc. I tried that and drove it around and it seemed to drive as it had before the spark plug change after the ECU got used to everything. Was a little sluggish, but after a few minutes of "spirited" driving, the car seemed to run fine again.
Still though, if normal for me is 170whp, then my problem is not fixed as, I should be running over 200whp and this was certainly not 30hp faster than what I consider normal...
Anyone have any thoughts?
