Warped161 wrote:the cheap crap from AZ is really lousy oil but even it should have enough viscosity to protect your motor. extremely fine metal particle can come from many sources in your engine, it doesn't necessarily mean it's toast. Install a magnetic drain plug to get a better idea of just how much metal your getting, it wont actually protect the motor but it will get all the metal in one spot so you get a better idea of how much there is.
the BEST cheapo oil is at walmart, it is sm rated like the good stuff(mobile one) honestly I think its made by mobile...
oil is oil in any event... as stated, and I too use cheap **** in the wifes jimmy, like 150k and 20ish mpg, with air on... honestly I should steal the motor out of it and do a 4.3 240...
your idle shouldnt be going that rich the lean is fine as no load to kill anything, teh eff bomb!!!1!!!eleven!! I run higher wihtout meth/water...
also how long were you letting the gassy oil be used? Doesnt take long, 3 miles wihtout oil and I have a slight tap on cold starts now
