Changed oil and man do I have problems
1watson
Just purchased a 92 Q45 that is in sweet condition with 98K. it is a "basic" Q model . A lady owned it out of Atlanta who moved to MI and decided to sell the Q. Absolutely clean but was in need of an oil change.
I changed the oil and filter. While spending countless minutes pondering how to get to the oil filter, I decided to removed the air box and access it from above. Big mistake. I have the following problems that appeared immediately after the oil change:
1. Very difficult to start, starter spins for ever and car wont start until I press the gas pedal to floor. Once started car runs ok but "misses" under load intermittently. Car idles fine. I was reading a post last evening and found that the MAF sensor/harness perhaps could be teh problem.
2. The check engine light is lit
What must I do to restore previous condition.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Um check the air box again. Chances are you didnt put it back on tight enough and/or you dislodged a wire harness in the process on moving it. Make sure all the connectors are secure and that the all hoses are in their proper locations.
