Hard to say on that. Mine was taking 2, 3 and even 4 pushes of the button at times before it would do anything.Ilya wrote:So that delay is a button issue? Mine, after getting new fobs, takes 1-2 seconds to respond before the car starts where as before it was much quicker.
I have a start button that I changed out the LEDs that I want to switch with my current button -DFW2011M56S wrote:Changed it over in about 20 minutes on my lunch break.
I know you posted this a while ago, but if you haven't gotten an answer and for any others who may want to do this. I had to remove the start/stop button when installing the remote start on my M37X.pedsemdoc wrote:I have a start button that I changed out the LEDs that I want to switch with my current button -DFW2011M56S wrote:Changed it over in about 20 minutes on my lunch break.
1. I got the silver surrounding bezel off
2. I pulled back the panel on the RIGHT side of the steering wheel and started to push out the button from below, but only got it about a third of the way until it won't budge.
Did you have to push really hard to get it out? any other pointers on making the switch?
I just don't want to break anything, so I chickened out and put everything back.
Craig
