Changed my Blower Motor & TCS pump & TCS ACtuator - oil change etc.....
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
old blower - was removed 6-8 mos ago disassembled cleaned and reinstalled. did not go together easily had to hammer the back plate back on, still worked better than before, but still doodie.Installed a blower off a 125k mi. after disassembly and cleaning, easy put together and was pretty clean inside (MINOR BRUSH DUST).A/C cranks about 1/3 more powerful and much more noticeable difference between speeds.also feelin like 100 deg. in NYC. so changed befor old one died.
TCS pump changed yesterday, still TCS does not work, actuator going in today. wheel sensors,computer,relays already changed.
BTY also had an oil changeM1 w/bosch filter, and repainted calipers.
jamesmost
abs actuator in - no difference, gonna install the tcs actuator next week and cross my fingers. my parts all have 360k mi. in them so replacing w/ 125k was not a bad idea anyway.
qship96
Car: 1996 Infiniti Q45
you have 360k on your 95? original engine? transmission? details wanted!
jamesmost
qship96 wrote:you have 360k on your 95? original engine? transmission? details wanted!
origional motor blew w/330krebuilt trans just before thatsuspension has 10k on it all new subframe bushings and all other bushingsjust painted 8 mos agoetc etc etcthe only thing that is origional besides interior and chassisis the Altinator even though it caught fire 4 years ago.
qship96
wow,the original transmission lasted over 300,000?
jamesmost
qship96 wrote:wow,the original transmission lasted over 300,000?
nice
