jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Sun Dec 11, 2005 11:40 am
there is a switch above the clutch pedal that tells cruise control when the clutch is engaged, this isn't the actual cruise control button however. that is used to adjust clutch travel and freeplay, it however does not change engage points which is what you are looking for. by loosening the nut on the pushrod and screwing the rod into the pedal you'll make the clutch engage later which should help you out. if anyone knows a precise way to adjust it and know where a good point is please let me know.
