changed master and slave now i can not get into gear
frost318
Car: 335i
I have a s14 sr20det. I recently had a problem with my clutch sticking to the floor. I Checked the slave cylinder and i had a leak. So i decided since i was going to change my slave cylinder i was going to do the master also. After installing both with oem parts on the car. So i started the car and tried to put it in gear could not get it in gear. My question is if the car starts then why i can not get it in gear?
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Well I hope you bled the slave cylinder. Crack the bleeder screw loose while a friend presses the clutch pedal. close the bleeder when he has hit the floor w the pedal, then let him bring the pedal back up and repeat until all fluid is flowing.
Otherwise, if you have an aftermarket clutch it's likely your clutch fork or clutch fork pivot bolt has broken or bent.
If you bled the clutch line, then it's time to pull the transmission sorry mangg.
frost318
Car: 335i
I did bleed the lines. I guess i will pull the transmission then
