Changed MAF on sohc, now it sputters.
erdrift
Car: 1990 240sx
So yeah i changed the MAF on my ka24e. Before the car wouldnt start and it would idle low then die. i changed the maf and it helped a lot. it doesnt die anymore but now it sputters and when i drive for a while i feel the car pull. any help on what this can be would be awsome. thanks.
rollout
Gabes13
Car: rb20det s13
1. Check your vacuum lines. 2. make sure your mafs is clean. 3. check if you have any gunk around the throttle body area. 4. if all else fails, run diagnostics on the ecu
