Just tryin my luck at this section, the KA section seems dead...The car has great pickup when its cold, when it heats up, it makes this crackling/rattling noise coming from the engine (only under load). But when the fan kicks on and everything's all warmed up, it lags like I'm going uphill. Gets to the point that the car cant even beat a bigrig with a trailer.
zerothread?id=119631
Just like the other thread states, I've replaced the fuel filter and fuel pump. Air filter is new, spark plugs are NGK Iridiums, dist cap/rotor and wires are all fine. Set base timing (at idle) to 20 degrees btdc. Just seams like the car wont accelerate as well once its under some heat. Feels like the car is starved for either air or fuel but I've addressed both issues. I hardly think it could be the spark plugs, I dont want to replace a new set just to find out it isnt the problem. Its definitely heat related, I'm hoping it wont continue during winter, but would like to fix it before. The only code the car is throwing is 32 (EGR), which theoretically shouldn't affect acceleration like this.....
NISTECH or any others, would appreciate any advice. Thanks~!
-R
