So, I've been doing an ignition tune up on my 2000 Pathfinder (VG33E). I replaced the plugs last week without incident. Today I changed my wires, distributor cap and rotor. I started it up afterwards, and all seemed fine at first, but then the engine skipped a few times. When I put it into drive, the skipping got worse, to the point the engine came close to stalling. I at first thought I'd gotten some defective parts, so I completely undid everything I did, and put the old parts back on. The skipping did not go away though. I followed the directions on this forum
how-to-replace-plugs-cap-rotor-on-1999- ... 27336.html, as well as the info in the FSM, so I'm 99% sure I didn't do anything wrong in the install. I tripled checked to be sure the wires were on the correct plugs, and the torque on the rotor screw was correct. As I continued the troubleshooting, the skipping only got worse. Currently the engine will barely start, and only if you give it gas and hold it at 2000+ RPM. The second you let off the throttle, the engine will stumble and sputter, and eventually die.
Before I started messing with the distributor today, the car has never had issues like this before. From flipping through other threads, the symptoms sound like my distributor has gone bad, but this is only a guess. And I really don't understand why replacing the cap and rotor would have caused this to start.
Any ideas?
P.S. Checked the car with my ScanGauge, no trouble codes.
