Flagship-Q »
https://forums.nicoclub.com/flagship-q-u29496.html
Fri Jul 18, 2008 2:28 pm
Hi all. Here's the skinny on the problems I have now. Finally (after 3+ yrs. ownership ) got around to switching out the plastic chain guides (1992, 118K). Pretty sure I did the operation correctly (zip tied chains up, etc.). While I was at it, I resealed valve covers, new p/s pump, A/C compressor, fuel filter, cleaned TB, AAC, Mass air, spark plugs and belts. I knew I had 1-2 bad fuel injectors and it still ran reasonably well but went ahead and replaced #1 inj. After ohming all, the #4 is toast (no ohm readings at all) all others fine. Now, the car will fire up and idle (shaking pretty badly too) for about 5-30 seconds and then dies kinda like it was starved for fuel. I cannot touch the throttle at all or it dies immediately. I get a code #21 (ign. signal circuit) and #34 (detonation sensor cir.) also. I've ohm'd the knock sensors and they are within spec (550). I've also tried to play a little with the timing without luck. The fuel pump "seems" to work normally . Sorry so long & I appreciate any help I could get!
