WESIDA wrote: well i've been racing quite much . if it should help, when i drag race i rev the engine up to 4000rpm, then let go of the clutch. i feel the nice power of rear wheel drive when the car starts to fishtail then just flies its beatiful man. then after than i let the engine go to 6000 on each gear. i got a feeling iam gonna get flamed for this
hehe, as far as i know its a stage 3 clutch from what the pervious owner told me. now i can't wait till i fix the car and put the turbo in there. dumb question bros but here goes. is it possible to have a turbo and a supercharger at the same timenametakennow wrote:4000rpm? Damn, I'd have wheelspin all over the place... BOTH of them (yummy LSD).
If you haven't properly warmed up or cooled off your engine after all that you could cause the head to disfigure from extreme heat without proper cool down.
The compression on KAs isn't such that a light turbo app is going to blow anything. I know that, at least for my SR20DE, I could run a good 16lbs of boost before things would get real hairy, but most people stick to 10-12psi on stock internals to prevent excess wear. I'd think a KA would be similar, but I'm sure the KA-T kids in that forum could tell you better.
Trust me, you won't be doing 4000rpm clutch dumps when you have boost unless you've got some drag slicks.
Haha, I'd like to see the remnants of a stock clutch that experienced that... lol.
true man, but its just ona those thoughts u know. i bet somebody outthere did it . do you drag race man, if so do you have any tips??nametakennow wrote:Yes, but it's beyond retarded.
Think about it, double the boost, sure, but it's not like your engine can handle that much pressure on stock internals (and you'd need MASSIVE injectors to feed the O2 coming in). PLUS it'd be amazingly expensive.
Ya man, thats the thing. getting the car off very fast and smoothley without burning off tires(at least not that much) but i guess sloppy drag racing is alright if u know you'll burn the other car eitherway heres a picture of my car btw, except no more wingnametakennow wrote:It's been done on a few cars, actually. I want to say there was an R34 in Japan that was running both. I bet it was a clutch-type supercharger so that when the turbo kicked in the wimpy stuff could be shut off.
Me? No. The car is FWD and is, and will continue to be, a daily driver. I don't have the money for tires, safety equipment, etc. I'm looking in to autocross in the relatively near future, then moving on to track racing...
what I wouldn't give for a few laps at Road Atlanta, even in my car as is...
I'll be finishing this car up in the next year or two and then moving on to a strictly-track project from there. I have a monster list of stuff I want to get done first though- it's time to move up from beating riced out Civics, stock Sis and Spec Vs .
However, I can tell you that drag racing is simple to learn, but hard to master. It's all in getting the right jump- not only in a timing sense but also in making sure you don't burn layers of rubber off.
A pure drag car is a delicate thing, because there's the balance in making the car get off the line, but keep accelerating the whole race.
If you'd read my later post you'd have noticed that I mentioned that cars that do have both must use something like a clutch-type supercharger to switch between the two. That's because you'd overboost and blow stuff up without it.paemt6220 wrote:when Supercharging and turboing and engine u would not get double the boost. the supercharger would make boost at low rpm until the turbo got spooled up. then u have to route the turbo air charge around the supercharger or have a clutch to disengage the supercharger. Mazda did it on the MR2 a while back. It had more gizmos and gadgits and things to F**k up than the FD's sequential turbo system(which is a lot if you no anything about them). Its a bunch of expensive crap just to get a little extra tourqe in the low end.
Go with a turbo like the GT28R(aka DISCO POTATO) and you can easily make 220-250hp at the wheels with only fuel system upgrades. And the best part is that turbo should make full boost at around 3000 rpm or maybe even less!!
Toyota made the MR2paemt6220 wrote:when Supercharging and turboing and engine u would not get double the boost. the supercharger would make boost at low rpm until the turbo got spooled up. then u have to route the turbo air charge around the supercharger or have a clutch to disengage the supercharger. Mazda did it on the MR2 a while back. It had more gizmos and gadgits and things to F**k up than the FD's sequential turbo system(which is a lot if you no anything about them). Its a bunch of expensive crap just to get a little extra tourqe in the low end.
