change topic
starkos14
Car: s14 R33*, 99 gs300(2jz-gte soon)
new scenario because the last post got rediculous and started to be a waste of time. im getting a S14 and will probably get a s14 notchtop clip from heavy throttle. how should i go about getting it installed in the Philadelphia area(or NJ)?
starkos14
and i do not have the equipment on hand to do it myself... i do have friends that have shops that can do honda motor swaps though but have never done the SR. i hope i have made the situation clear.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
starkos14 wrote:and i do not have the equipment on hand to do it myself... i do have friends that have shops that can do honda motor swaps though but have never done the SR. i hope i have made the situation clear.
Use your friends the swap is pretty easy and straight foward. all you need is wiring service done and you just plug it up everything just bolts on mount are the same driveshaft ect. just my 2 centavos
starkos14
anywhere i could just order the wiring? plug and play style, or do i need the motor and ecu first. where could i have the wiring done? this is my biggest concern
silvia-junkie
Car: s14 kouki
for wiring go here http://www.wiringspecialties.com/ just sent them boath ka and sr harneses and they will do the rest
sean8564
1993 Nissan Silvia
Mckinney motorsportsthey sould have the wiring there
