To me they do bite a lot better. The only donefall for them is the pads, I had semi metallic with them and they got eaten out by the rotors in a years time.Ron Burgundy wrote:Drilled rotors eh?
How do you like them? Notice any difference?
I need to do this, what immediate benefits are given from doing the replacement?Ron Burgundy wrote:Yes, I have.
Its very simple. Unscrew the distributor cap (one screw on each side) and pull it off.
The rotor is right underneath (I reccomend looking at it before buying a new one so you are sure you are getting the right one). If thew screw is facing you - awesome unscrew it pop it off and put the new one on.
If the screw is not facing you, close it up and start the car so it rotates, stop the car and check it again. You'll get it sooner or later.
Very simple job, should take no more than 5-15 mins.
FYI: If you're thinking about doing this on your '01 Pathfinder with the 3.5 engine, then good luck. There is no distributor or rotor on that engine.sixty4 wrote:
This is the step for removing rotors:Remove brake padsRemove CaliperOnce the caliper is remove, do i remove the hub and rotor or do i remove only the rotor. i am a stuck on the this part?Mikey178 wrote:Not sure if your asking about the brake rotor or distributor rotor. Seems like Ron gave you the instructions for changing your distributor rotor.
I've changed my brake rotors to the drilled rotors and I reused the center hub. Just remove the bolts and the screws that holds the rotor, I believe there was 3. Then install the new brake rotor and attach the hub. Its quite simple but very straight forward. Not sure if my explanation is correct but its been a while and it was easy from my memory.
