%%%% Change? %%%%
pimpingurz
is it ever too late to go to synthetic oil no matter what mileage you have? mechanics told me it wasn't a good idea. i think that they didn't want to take 5minutes out of their time to order some for me. what do u guys think?
PalmerWMD
Car: 2004 350Z
You can always go to syns.the bests results are acheived if you go to them early inn acars life as so muchb wear occurs early, but its never to late to get their benefit.
Fred..:)
pimpingurz
that's wut i thought, i think they were too lazy to order the oil cuz they didn't have them in stock. they were giving BS answers that i knew wasn't true. guess if you wnt things done right you do it yourself.
thanks for the tip palmer
Jberger
Back in the early days of synthetics, a change late in engine life could cause leaks. As some synth blends cleaned off the residue built up over time. They also didn't have the same seal swelling properties as most dyno oils.
This has not been much of a factor in the 90's as the synths have been improved and so have most gasket/seal materials.
