djtorello »
https://forums.nicoclub.com/djtorello-u90321.html
Sat Mar 20, 2010 10:15 am
12"s wont fit unless you cut the rear deck out, to a much larger size. Ive replaced to Stock RF 8"s with RF p2 DVC subs. If you decide to run the stock amp, make sure your subs are 2 OHM.
The Amp is already hooked up properly. BTW, no matter what subs you have, the stock RF headunit is going to auto adjust the bass down after volume 15. In order to bypass this function, and make your speakers/subs sound awesome, you are gonna need a quality line out converter, like JL audio clean sweep, or in my case, MTX ReQ5.
