Change Rear Brakes on 91 Q45
Christine_Tampa
Car: 1991 Q45a and Q45
Could someone please walk me through the process of changing the rear brakes, Also is there anthing special with this car I need to do/buy/or check while doing the brakes?
Thank you for your help
Christine
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Are you installing the J30 rotors and calipers?
If not, then just look at the FSM.
Dial guages and brake lathe are both good to have access to.
OEM pads only.
Christine_Tampa
Hmm is there anyway to explain this without sounding like a dumb womanThe book doesnt really explain it in lamest terms. This will be my first time changing brakes. Since I can not afford a mechanic I figured I'd try it myself thinking it wouldnt be to hard. (maybe I was wrong) None the less it has to be done
I googled a lathe That is not something I have laying around also http://www.jcwhitney.com/webap...10101 Is this the dial gauge you were talking about?
Rex
Car: None
Christine_Tampa wrote:Could someone please walk me through the process of changing the rear brakes, Also is there anthing special with this car I need to do/buy/or check while doing the brakes?
Christine
This may seem overwhelming, but it's just very detailedhttp://forums.nicoclub.com/zerothread?id=47476
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
To do the overhaul correctly, you need to check runout or have them turned after checking rotor thickness. High temperature lube grease, torque wrench if the rotors come off, and a shim kit on hand in case it is required.
Now, what about the emergency drum brakes?
And the front brakes? Irregularites there can quickly undo all your good work on the rear ones if the defects are not remedied at the same time.
