superDorifto »
https://forums.nicoclub.com/superdorifto-u29662.html
Mon Aug 29, 2005 10:57 am
Im still saving for internals, but today i started to tackle the nagging little bits of rust, that left unchecked could become a major problem down the road.
total cost of today's affair-----~$10both of these products were bought at my local advance auto parts for like $5 a can.... this is a brush on rust eliminator.. there are lots of different brands, but they all work pretty much the same. take a wire brush and remove as much of the rust scale as humanly possible. brush on a liberal amount of this chemical to neutralize the oxidation reaction causing the rust in the first place. let it dry completly, and the rust should have turned black...it is now safe to coat with your choice of finish....
once again there were alot of undercar coats, brush ons and spray ons. I chose this one because i personally like duplicolor products. If it comes in a rattle can theyre prolly your best choice.
im ready to start
before i started sprayin everywhere i washed the entire area with some mild dish soap to get rid of all the debris, and let it air dry...
next step was to remove all the scale and loose rust i could...i fogot to take a pic of this, opps
heres a couple before pics of the passenger side rear fender well before aplying the rust remover....
the remover took about an hour to dry completely, and when it did i went to town with the undercoat.
i was afraid it wouldnt be thick enough, WOW was i wrong, it coated like it came off a brush...
im VERY happy with the resulting coverage and plan to finish up the rest of the underbody this week. i figure with the coverage i want, 5-6 cans will be more than enough to finish the car. The bottle of rust remover should last thru the whole project as well.
total cost ~$40...score
