Change miles to kilometers on the display.
B52
Car: Infiniti Q45, 1993, Black Obsidian,
Infiniti Q45, 1994, Black Obsidian,
Infiniti Q45, 1993, Green,
Infiniti G20, 1995, Blue,
Nissan Xterra, 2005, Night Armour,
Chrysler Concorde LHS, 2002, Gold.
Hi,
how to change the view display miles to kilometers in Q45 of 1994, I am of Polish and help me a ride ...
I searched but could not find.
Thank you, Chris
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
I think you just press the reset in instead of twisting. I remember it happened to me before.
B52
How do I push it, I received a message that I have to change pads and car mileage in miles. I do not want to change to kilometers.
Q451990
You may have to cancel the brake message (replace pads or fool sensor) before it will let you change the distant unit.
Heath
B52
It is possible that I can not change for miles because of the brake pads that I have installed. Brake pads without the sensor with cable, I see that the cable is attached to the plastic quick release and is not connected anywhere. That's probably the cable from the blocks just no place to plug it. The pads have a metal badge, which squeals like a little block.
Thanks for you help. :)
Lokim
Car: 1994 Infiniti Q45 acquired 4/25/10 w/192K
Now at 222K and going strong!
Just run a small piece of wire from one side of the harness connector to the other to short it out. I did that on my 94 and it shut the message off.
B52
Lokim wrote:Just run a small piece of wire from one side of the harness connector to the other to short it out. I did that on my 94 and it shut the message off.
You could accurately describe it?
