Change low beam bulbs on 2005 Altima
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
belleduke
Car: 2005 Nissan Altima
Please help me, low beam bulbs on 2005 Nissan Altima. Driver side, how to change?
How to get access to the location of the bulb????
Thank You
Reason: Revise Title
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
I take it you dont have extremely small hands? Seriously, I have found that un-bolting the air filter box and moving it out of the way helps access the drivers side headlamp assembly. You can also just pull out the plastic bellow that traps water and drains it out through the wheel well. With those two air-boxs removed you should have plenty of space to access the assembly. I dont think that you have to take off the air scoop that is connected to the front of the engine bay. Those are held on by a few plastic fasteners. If you have problems let me know.bud
Return to “3rd Generation Altima Sedan (2002-2006)”
