95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Fri Jun 23, 2006 2:03 am
Okay, so I needed to install the gasket, so i ended up buying one anyways since it wasn't expensive and i've seen them in my experience to be very robust. i didn't think i would like any other sound from the exhaust, but i have to say it's at least as good as the popping, burbling stock exhaust note. now it's very smooth - you don't hear "individual" cylinders firing, you hear as was said a smoother, more refined note, but it still gets nice and pissed in boost. overall i like the sound. i haven't had it on the dyno since i was at 7psi (now i'm at 12psi w/ i/c, new BOV, turbine outlet, and manifold), so i can't test gains, but i'm hoping to hit the dyno today or tomorrow and hit ~225whp. but as i said i'm not concerned with the 5-10hp possible gain from a manifold at this stage. i just want to hop on the dyno to make sure she's running right (if it's running right it will make good power and have good a/f ratio).
