change headlight bulb.
General discussion area for the L32-chassis Altima
herc0550
Car: 09 altima sedan (dark slate)
i bought some new bulbs for my 09 altima sedan and found out i couldnt do it by the hood. so im guessing its by the wheel well. but can someone please tell me for sure and if you can please on how to do it and pix would be great.
trayharrell951
Car: 2008 Altima 3.5SL. 2005 350Z, 2010 370z SP
Good luck lol your gonna have to go under the wheel well or easiest way to change it is take of the front bumper. Now for all the work you should go hid lights not just the bulbs....also use the search buttom very useful.
lyon74
Car: 2007 Nissan Altima
Start the car. Turn the wheel all the way to one side. Shut off the car. Pull on the inner fender well (plastic) and you'll see the bulb. Unplug the bulb and twist counter clockwise. The bulb is now out. Put the new bulb in in the reverse order. You'll need to start the car and turn the wheel the other way to do the other side. Goodluck!
herc0550
iight thanx guys. i ended doing it by the wheel well. it was extremely easy. the bulb was right there after you pop it off. just to let u no lol i also changed all my map acc and license plate lights to orange leds. look pretty siick. thank for the help guys!
Return to “4th Generation Altima Sedan (2007-2012)”
