Change front drum brakes to disc brakes
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Kerrin
Car: 1982 Datsun 1800 King Cab 720 series 2WD
Hello
I want to change the front drum brakes on my 1982 1800 king cab to disc brakes.
What model can I get the disc brakes from and are there any modificatins required?
Thanks
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Disc brakes from any 720 would work without any modifications. You just need the complete spindle with the caliper and the disc for the conversion. There are other brake systems that work also and are a slight upgrade to the original. The front disc and spindle from the nissan caravan (E24) is a direct bolt on for the ball joints but the hole for the steering end needs to be shimmed or welded and reamed to suit the 720 end. Also the flexible hose would have to be changed.
Kerrin
Thanks for that, flinterman2000.
I'll have to track another old girl down
Kerrin
Charlie69
Car: 1966 Datsun 520
In the US 1980 & up had disk brakes from the factory. What country are you in?
Return to “Datsun 720”
