paranoidjack wrote:I'm surprised to hear that, since coming from an '00 Q45 the coil packs were HUGELY problematic...so the VH45's don't have this issue? Good to hear but hard to believe.
Hold on now, don't go blowing your coilpack savings quite yet if you've always had bad luck with coilpacks. [
This will be long, but here is how I justify my recommendation]
Electronic/ electric components can be interesting. If you have a manufacturing defect your new coilpack will either not work, or just die shortly after installation. If you mishandle it such as drop it from an unreasonable height, one of those 2 situations might happen. Again, if the manufacturing specs are off, one of those might happen (this is why I go for OEM only on some of my replacements). On the other hand, some electronic components pretty much outlive the car, for example the Engine Management computers.
... then there's the classic abrupt and random failure; which the OP's could be.
I had a 2001 q45 for a pretty short time but at 256,000 miles I think the coilpacks had only been replaced once, assuming with the updated ones, if that had been a problem. Same thing happened to the 2000+ maximas with their goofy coilpacks but updated versions with grey dots were way more reliable - manufacturing standards changed??
The spark plugs though, those are wear items. You keep shooting electricity through metal and give it numerous explosions and at some point it will wear out. In my mind, if one cylinder has a spark plug worn enough that the gap was off enough to throw a code, the other ones might not be too far behind. I suppose you could just regap and continue. Of course this is assuming all other components are operating like they should.
This is all just one guy's experience and your results may vary. Plus, I haven't really heard of many complaints from VK45 owners about coilpacks.
