un_known »
https://forums.nicoclub.com/un-known-u18139.html
Fri Sep 17, 2004 7:48 pm
Join the club, I know this isn't much help. I'm going to go ahead and assume that you don't have side marker lights either. Check all your fuses, if you're lucky you'll find some that are blown. The fuse box is on the driver side kick panel, I pray that you knew that already. If you're not lucky, then you'll be like me and about 40,000 other people with the same problem. If you have a fuse, I don't really remember which one because it was a while ago and its about 2:30 in the morning. But it'll be a 15A fuse. If thats busting my best suggestion is to unplug all your exterior lights (not just the bulbs its self, but the whole bulb housing, there should be a simple clip). Then turn on your headlights and if the fuse doesn't pop then start plugging lights back in one at a time being sure to check the fuse after each new attachment. Im sorry I couldn't be of more help, but I'm still without dashlights.
