skywise6854 »
https://forums.nicoclub.com/skywise6854-u28443.html
Thu May 26, 2005 7:21 am
so far everything is going great got half the car apart doing the plenum hoses chain guides knock sensors transmission coolerand two bad fuel injectors but the question i have is - how do i remove the oil pump chain both prockets spin freely and i cant slide the sprocket off the crank - do i have to remove the oil chain guides first ? or do i have to remove the gear thats on the oil pump and then what do i brace it against when trying to turn the bolt
i dont know if this matters but its an active suspension
