louiegz »
https://forums.nicoclub.com/louiegz-u10925.html
Thu Dec 02, 2004 9:54 am
I don't know if my opinion helps, but this is how I feel on the subject of chain guides. You have to ask yourself this very important question. Do you plan to keep the car for a long time? If you do then it should be the first thing that you should do before anything because once your chain fails, the car is junk. New engine. If you don't plan to keep your Q, then drive it until it dies, but don't invest any real money on the car and just be aware of the fact that when that chain fails and destroys the engine, that's it. Your Q is toast. I know that it sucks to spend that kind of money on something that was an Infiniti design error. I have a 95 Q, so I don't have this problem. I didn't know about the chain guides before the NICO, but personally, if I had a 90-93 and I found out about chain guides problems, I probably would have sold it and let it be someone else's problem. You can also look at it from the other side of the coin. If you had a car that had a timing belt, like the 1994 Honda Accord EX that I had, at 85k the timing belt had to be replaced at a cost of $900.00 at the dealer. I sold the car at 75k, so I didn't have to replace it, but I sold it to someone that I knew and warned them that it would need to be done. Chain guides cost much more that $900.00 so this might not be an apples to apples comparison, but close enough. So I go back to the original question. How long do you plan to keep your Q?
