DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sat Feb 01, 2003 2:03 pm
Your timing chains will probably last another 100-200k; the kit includes them, for about $120. Call Scottsdale at 1-888-216-5328. I can't say enough about how pleasant and professional those guys are. They really take care of us.Scottsdale also has the plugs you need. Use the factory NGK ones and *nothing* else. Yeah, they're a little more than other plugs, but they won't fall apart into the combustion chamber either. I agree, the under-plenum hoses and valve covers probably need to be done. But, if that's too large an expense at one time, then they can probably wait for as long as you can stand both the smell from the exhaust manifold and the oil puddles on the ground. Those 2 jobs should be done together, but there isn't a lot of labor overlap between them and the guides. However, there is a good amount of overlap between replacing the plugs and resealing the valve covers.Thermostat yes, water pump, I'm not sure about. The part is $100. Mine has 216k on it, doesn't leak, and is smooth and clean on the inside. Also inspect the thermostat cover and replace if corroded. VERY important part. Inspect the large coolant hoses and the belts, and be prepared to replace any or all of them. Replace the fan if it looks like there's any risk it'll throw a blade.
Congrats on your new ride!
