forecast »
https://forums.nicoclub.com/forecast-u7026.html
Sat Jun 28, 2003 12:19 pm
You have two options
1. Do the overhead hoist method. This is safer, but the hoist gets bothersome since the legs will occupy your workspace.
2. Put a block and jack under the tranny bell, and let the engine hang "rebuild stand" style. This requires a concrete floor and a vow never to get physically under the engine.
All Q's have hoist point in the top rear RH side. The front LH side point almost never has the hoist point. Get a long bolt equivalent in size and thread to the AC compressor to bracket bolts and bolt a chain to the LH head on the side, above the exahust, about where the power steering tube descends from the resivoir. At that point there is two side by side holes in the head. The rear one will have a bolt and a grounding strap already in it.
You'll be pulling the AC compressor anyway, but I'd recommend against using one of those bolts to bolt a chain to head because of the risk of bending it.
