Chain guides... how to remove oil pump chain?
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Sorry for the stupid question... but, i can't figure out how to remove the oil pump chain. In the Tangalora's write up on the topic of doing chain guides she posts the following...
tangalora wrote: - Remove the oil pump chain, guide and sprocket (which is not keyed).- Note the oil pump crankshaft sproket has a key cut.- This oil pump crank sprocket keyway isn't used to hold it in place.- Compression/friction of the 270 foot pound crankshaft bolt holds it.- This oil pump sprocket keyway is there only to put it on the crankshaft.- Cinch timing chains tightly to prevent jumping a sprocket tooth.
I am looking at this and can't get it through my dumb skull. I took off the guide, but don't see how to remove the chain without removing the drivers side sprocket. Any hints on how to remove the chain and chain sprocket?
ceningolmo
Nevermind!
