The message is a result of the sensor being worn. If the replacement pads didn't have (or he didn't install) the sensor, you'll continue to get the message. It's also possible he only did the fronts or rears and the other axel needs new brake pads as well.Bodge420 wrote:also do you know if the previous owner put on new brake pads will the check brake lights remain on until I get the proper pads or is he just talkin smak?
Some on here have had their engines ruined, but most are smart enough to heed the advice and address it quickly. The "missing pieces" just mean you hvae to pull the oil pan to find all the pieces or risk the pieces getting caught in the oil pump/chain creating comparable damage.Bodge420 wrote:did it ruin your engine? how many miles were you at when you replaced them?I cant beleive they used PLASTIC!
That happened to one of our members, PalmerWMD.Twice I think....nuQ wrote: i lucked out and the chain stayed put (i still think back on if the chain jumped while i was driving the hour to the shop coming directly from the guys house that i just bought it from. that would have S*CKED ROYALLY!).
my chain starting eating into my oil pump. didn't go through, just scored it pretty good, but to be on the safe side, i replaced the oil pump too.elwesso wrote:Many MFGs still use them! on some of the chain driven lexus/toyota engines, i heard that theguides can fail and the chain starts eating into the timing cover.. it will eventually eat all the way through it, resulting in a large oil leak...
PopPop wrote:Actually I think valve covers are typically not done... at least in a T3 job. The only reason to remove the valve covers is if the engine slips time (about 1 out of 10 jobs statistically) or they're leaking (like mine were) - otherwise no overlap. Plenum removal isn't necessary for either valve covers or timing...Q45tech wrote:6-8 hours charges are a little low we usually require 10 hours..........plus almost always there is a problem with the accessory belts or idler pullies. When Wes said 6-8 hours he was probably talking about the time it takes to replace timing chain guide parts! I know Techs always include valve covers but, some people do the T.C. guide job without doing the valve covers! The 10hrs you spoke of probably includes plenum removal which some do not remove when doing valve covers!
Heath
Yes Heath I agree with you thats exactly what I was saying but, most Nissan and Infiniti Dealers will say they will have too remove valve covers, Plenum and or both to do either one of those jobs but, not necessary!Q451990 wrote:
Heath
Oh, I got it... sorry for the confusion. On my last guide job those parts of the head gasket were covered with RTV before resealing. Seems to be working well.PopPop wrote:Yes Heath I agree with you thats exactly what I was saying but, most Nissan and Infiniti Dealers will say they will have too remove valve covers, Plenum and or both to do either one of those jobs but, not necessary!
Amen to that! Like replacing the helicoiled front cover. Parts cars are a beautiful thing... and the fact that T3 actually cleans things before resealing.Q45tech wrote:It's the little extra things that count and never get charged for while doing the main job.
Interesting. Most Toyota (and Honda) mills use the dreaded (by me) cogged belt drive for their camshafts. Easier to design, I suppose.elwesso wrote:Many MFGs still use them! on some of the chain driven lexus/toyota engines, i heard that theguides can fail and the chain starts eating into the timing cover.. it will eventually eat all the way through it, resulting in a large oil leak...
