I just called Joe but he wasn't in. I talked to a guy named Leon. He had at his disposal a parts list for the job. This is what he emailed me.
13070-60U03 ASR 1 TNSNR CHAIN V02D 60.38 60.38 13070-60U12 ASR 1 TENS CHAIN V02D 60.38 60.38 13075-60U02 ASR 4 BOLT-TENSIONER V02D 1.69 6.76 13079-60U01 ASR 1 GASKET-CHAIN TENS V02D .80 .80 13085-60U01 ASR 2 GUIDE-CHAIN,TENSI J06 18.17 36.34 Service File comments exist for part. 13085-60U11 ASR 2 GUIDE-CHAIN,TENSI V02D 8.69 17.38 13091-60U01 ASR 1 GUIDE CHAIN J06 64.15 64.15 13091-60U11 ASR 1 GUIDE CHAIN J06 64.15 64.15 13510-60U00 ASR 1 SEAL-OIL CRANKSHA BC2B 5.48 5.48 15041-60U00 ASR 1 CHAIN-OIL PUMP DR V02H 44.72 44.72 15073-60U00 ASR 1 GUIDE-CHAIN V02H 8.05 8.05 15073-60U10 ASR 1 GUIDE-CHAIN V02H 48.71 48.71 999MP-A7007P 1 GASKET SILICONE L BCNTR 18.13 18.13
I asked him to email me his list because the list I was reading off of had some part numbers that he couldn't find. It also listed 2 timing chains. I was reading off of this one.
http://www.nicoclub.com/articles.php?id=164335
This is what it said:1x 13510-60U00 - front cover seal- 2x 13270-60U00 - valve cover gaskets (if valve cover is removed)- 4x 11051-60U04 - cam end seals (if the valve cover is removed)- 1x 13091-60U01 - guide (tension RH)- 1x 13091-60U11 - guide (tension LH)- 1x 13070-60U03 - chain tensioner (RH)- 1x 13070-60U12 - chain tensioner (LH)- 2x 13085-60U01 - chain guide (tensioner guide?)- 2x 13085-60U11 - chain guide- 2x 13094-60U00 - guide bolts- 2x 01121-04711 - guide bolts- 4x 13075-60U02 - tensioner bolts- 1x 13079-60U01 - tensioner gasket (LH)- 1x 15041-60U00 - oil pump chain (highly recommended)- 1x 15073-60U00 - oil pump chain guide- 1x 15073-60U10 - oil pump chain guide- 1x 15072-60U00 - bracket oil pump- 1x 15044-60U00 - crank/oil sprocket- 1x 15043-60U00 - crank/timing sprocket- 2x 13021-60U00 - crank/cam sprockets (if warranted)- 2x 13028-60U00 - timing chains (if warranted)
Then, after more searching, I found a list that said:2x 01121-04711 - bolts for new guides 4x 11051-60U04 - cam end seals 2x 13021-60U00 - crank/cam sprockets 2x 13028-60U00 - timing chains 1x 13070-60U03 - chain tensioner(RH) 1x 13070-60U12 - chain tensioner(LH) 4x 13075-60U02 - tensioner bolts 1x 13079-60U01 - tensioner gasket(LH) 2x 13085-60U01 - chain guide <----------------!2x 13085-60U11 - chain guide <----------------!1x 13091-60U01 - guide(tension RH) 1x 13091-60U11 - guide(tension LH) 2x 13094-60U00 - guide bolts 1x 13510-60U00 - front cover seal 1x 15041-60U00 - oil pump chain 1x 15043-60U00 - crank/timing sprocket 1x 15044-60U00 - crank/oil sprocket 1x 15072-60U00 - bracket oil pump 1x 15073-60U00 - oil pump chain guide 1x 15073-60U10 - oil pump chain guide 2x 13270-60U00 - valve cover gaskets
zerothread?id=13851
Which is the one that I should go by? I know I need the valve covers resealed as well. I've read some members pay less than $350 for their parts. Leon quoted me $562 and change. Which ones are the parts that I absolutely need? I'd ask DAEDALUS but I haven't seen a recent post from him.
Sorry to be a bother, but I'm not sure on what to do and I'd hate to get the wrong parts and be stuck with them.
I just added up the amount for the list that Leon sent and I got $435.43. The website says that these two parts can't be found:13075-60U02 & 13079-60U01. My shopping cart total is $401.01 without those two parts. Why do I keep getting different totals?
The list that was posted by PalmerWMD gave me a shopping cart total of $564.17 and had a bunch of parts that said "Part not found".
My Q has 90k+ (like 90,3something. Can't remember at the moment). The engine runs fairly well. Which of these parts lists will I be needing? Anyone that's done this recently, please help.
Modified by Haitian_King at 3:46 PM 1/9/2008
